 :: PCMods Server Window Kit and the Dremel MultiPro Super Kit
The Products
The Dremel MultiPro Super Kit is a multi-purpose kit designed to assist in a wide variety of projects. Included in the kit are the variable speed multipro dremel rotary tool, flex-shaft attachment, keyless chuck, collet wrench, deluxe storage case, as well as the 76 assorted bits/accessories listed below
1 - #150 Drill Bit
1 - #191 High-Speed Cutter
1 - #401 Mandrel
1 - #402 Mandrel
1 - #403 Bristle Brush
1 - #407 1/2" Drum Sander
3 - #408 1/2" Coarse Sanding Band
36 - #409 15/16" Cut-Off Wheel
3 - #411 Coarse Sanding Disc
12 - #412 Medium Sanding Disc
3 - #414 1/4" Felt Polishing Wheel
1 - #415 Dressing Stone
1 - #422 Felt Polishing Tip
1 - #423 1" Cloth Wheel
1 - #425 Emery-Impregnated Polishing Wheel
2 - #426 1-1/4" Fiberglass-Reinforced Cut-Off Wheel
1 - #429 1" Felt Polishing Wheel
4 - #432 1/2" Fine Sanding Band
1 - #8193 Aluminum Oxide Grinding Stone
1 - #84922 Silicon Carbide Grinding Stone
1 - #932 Aluminum Oxide Grinding Stone
The multipro dremel rotary tool features a variable speed switch offering 5 different settings. Each setting increases the RPM's by 5000 with a max of 30,000. The multipro also features easy motor brush replacement as well as an integrated hook for easy storage
The included flex-shaft is a great feature. It allows for greater control, precision, and flexibility when cutting or drilling. It works especially well when trying to get into those hard to reach areas.
The keyless quick change chuck is a great addition to this kit. It allows for quick swapping between various bits and accessories.
Included with the kit is also a nice case which accommodates all of the accessories included with the kit. It features front easy-open compartments as well as flex-shaft and accessory storage inside.
The PCMods Server Window Kit is an all-in-one kit for adding a window to a sever case. It features a cast acrylic window (Available in blue, red, or smoked), pre-cut window molding, locking strip, spacer and instructions. The acrylic window is protected by a plastic covering on both sides to guarantee that it arrives scratch free. The window is laser-cut to provide precision cuts.
Step by Step Installation
